LabWindows/CVI
how to get bar graph in word in labwindow/CVI ?
(3,722 Views)
ashwinic9,
spawning your question over more and more threads (the present one, this one and this other one) won't give you a faster answer; instead, it will irritate forum users! Smiley Mad
Especially if you have at your disposal a fast way to perform a test. I pointed you some days ago to word report example, that writes a table to a word document: did you tried changing the graph into a bar graph and generating the report? I have done it for you and the result is OK, as you can see in the attached document.
Now, since the example works well, there must be something in your particular situation that prevents the graph to be shown; that is: you must add some more data on your actual problem and maybe a small example that exposes the problem.
But please: keep active only this discussion and let the other threads die! Smiley Wink
(3,713 Views)
