LabWindows/CVI
how to get .jpg graphic file output from DOS labwindows screen graph panels or convert saved .prt file to .jpg format
Have DOS labwindows 2.0 and need to be able to generate a .jpg graphics file of data output to the screen on a panel by the plotwaveform command. Output panel can be used to save the panel as a file .prt or HPGL format - can these be converted to .jpg format ?
Message 1 of 1
(2,696 Views)
