LabWindows/CVI
how to get the return value of external application
Hello All,
I am creating an application in labwindows cvi 6.0. I have an external executable and this executable is displaying video  from a USB device. I know nothing about htis executable. And I want to call that executable, display it in a panel or picture control on cvi and then get the return values of that executable. Is there any way i can do it in labwindows cvi?
thank you very much for the help.
________________________________________________________________
Electronics Manufacturing Tester Forum
(3,034 Views)
Hi smoken,
As far as I know there is no current way to embed a random executable that has a GUI inside a LabWindows/CVI panel. If the executable contains an ActiveX interface, you could possibly use our ActiveX wizard to generate a wrapper and call the exposed methods and retrieve/set properties of that executable. You can also embed ActiveX controls inside a panel (such as using Windows Media Player to show video). For further ActiveX support, see the What ActiveX Features Does LabWindows/CVI Support? KnowledgeBase.
To simply launch the executable from LabWindows/CVI, you could just use the LaunchExecutable or LaunchExecutableEx (depending upon CVI version) function.
If this USB device is a camera, you might want to check out the Vision Module available in LabWindows/CVI.
Hope this helps!
Best Regards,
Jonathan N.
(2,988 Views)
