LabWindows/CVI
how to install labview fpga for win32
Dear all ,
I want to know how LabView FPGA works, and programming style for FPGA module. For that i have downloaded evaluation software "LV86FPGA_1.iso" and "LV86FPGA_2.iso" from NI web site. When i tried to run setup, i had error LV86FPGA_1\setup.exe is not a valid Win32 application. I have windowsXP OS and 32bit computer. I want to know that Labview FPGA can't run on Win32 system or what i have downloaded is wrong?
--Vishnu
(3,966 Views)
Hi Vishnu, this question relates to LabVIEW and some additional tool for it, so you should post is to the labview forum, where some person that is using such module can help you on this.
(3,947 Views)
.iso files are usually CD or DVD images,which you should burn to a CD or DVD before using. You saw setup.exe only because you have installed a viewer program, that allows you to look into that iso file. But you can't start an executable directly from that iso file.
PS: You should have posted that question into a Labview forum, not into the Labwindows forum
(3,946 Views)
Dear Markus,
Thank you very much.
--Vishnu
(3,914 Views)
