LabWindows/CVI
how to load a parent panel in a new thread
for a communication dll, i need to load a panel witch visualize all the data transfered.
But as it's a dll, there's no "RunUserInterface" running.
I think the way is loading this visualization panel in a new thread.
The problem is that it's the only panel i need to load (then it's a parent panel)
How to?
JMCe
(4,022 Views)
There's no reason a DLL can't call RunUserInterface.
When you use the UI Editor to create a user interface and generate the code for it, it creates functions InitUIForDLL which calls LoadPanelEx and DisplayPanel. It also includes a commented out call to RunUserInterface noting that you can run it from there or elsewhere in your code.
It's common in multi-threaded apps to have the user interface in one thread and other functions (liek data transfer) in another thread.
(3,996 Views)
You can look at some of the samples that ship with CVI like
...\CVI\samples\utility\Threading\ThreadPool\OnePanel\OnePanel.prj
and
...\CVI\samples\utility\Threading\ThreadPool\MultiPanel\MultiPanel.prj
(3,995 Views)
You can also look at ..\CVI\samples\dll\gui to see how to load a panel from a DLL, where the DLL is calling RunUserInterface.
Bilal Durrani
NI
(3,975 Views)
to clarify, i never code any multithreading application, i'll try now !
I've looked for UI editor, and i don't find any reference to a InitUIForDLL function.
is it UI to Code converter in CVI 7.1 ??
JMC
JMCe
(3,974 Views)
InitUIForDLL is a function that the UI Editor code generator creates for a DLL project with a user interface. In the sample program Bilal refers to, the function is called RunDLLUI. Look at that project.
You can see the code automatically generated by doing the following.
Create a new project.
In the project window, go to Build >> Target Type >> Dynamic Link Library
In the project window, go to File >> New >> User Interface
In the UI Editor, right-click on a blank spot and select Custom Controls >> Quit Button
In the UI Editor, go to Code >> Generate >> All Code.
Name and save any files as prompted.
(3,965 Views)
Hi all,
this dos'nt answer my problem.
I thinki've solved my problem  with this application i've developped last week :
a panel loaded in a new thread witch display results on the fly .
JMCe
(3,951 Views)
