LabWindows/CVI
how to load text files in GUI
plz tell me .. how to load and compare two text files using file popup's . example file i have attached..
(4,215 Views)
I don't understand whether your question is on how to load text files or how to show them on a panel or how to compare them... or all aspects together!
The first operation (loading the file) can be accomplished with functions included in the Formatting and I/O Library like OpenFile, ReadFile and so on; with a file like yours even FileToArray could be an option.
How to show the data on screen is heavily dependent on what you intend to do with them: data can be shown in textboxes, listboxes, tables or graphs so... what do you want to do?
The same applies with comparison: without additional details is difficult to give you the proper hint.
(4,200 Views)
Do you want something like that ? (see ZIP attached)
> You can click on "file 1" control to make a popup appear.
> Same thing for "file 2".
> Click "COMPARE" button.
In the ZIP, you will find 2 text files for testing...
Be careful...that's just a quick example : if you take this you will need to handle file errors ! Moreover there are probably some particular cases that I have not handled.
(4,136 Views)
Note that using 1 for loop for each colum of the table (so 3 for loops) is a little bit dirty...I should have used only 1 for loop !
(4,132 Views)
