LabWindows/CVI
how to make a child panel float over parent
 iwant to make my child panel to be kept away from  my main panel and i have to process main panel..
then after some time  i will start working with my child panel..
if i move my child panel it gets moved inside main panel not out of main panel..
could u tell me the best to do it..
regds
SKS
(3,044 Views)
Hello SKS,
child panels will always be limited to the boundaries of the parent panel. If you want the panel to be independant, you should not make it a child panel. Just load the panel with '0' as the first parameter of the LoadPanel function.
(3,039 Views)
