LabWindows/CVI
how to make listbox to scroll auotmatically as list iems are added continuously
Hi All,
I want to to make listbox to scroll auotmatically as list iems are added continuously means if i add one list item it should become active and if i add second item it should become active and list box should scroll automatically to last element.I should be able to see that scrolling in UI.
I need this functionality to know at this point of time i am on which line in the list box.Please help me in this regard.
Harika
(3,922 Views)
I am not aware of a way to operate automatically this way: when I need such a functionality I simply add some line to my code:
InsertListItem (panel, control, -1, "text", value);
GetNumListItems (panel, control, &numItems);
SetCtrlIndex (panel, control, numitems - 1);
ProcessDrawEvents ();   // Optional, in case you do not process events other way in the code
(3,921 Views)
Hi Robert,
I am using same way in my code. But what happening is : i am able to see the contents of the listbox only after inserting all the items.
For example, if i want to insert 100 items, list box is empty till all the 100 items are inserted.I am not able to see the listbox update for each item.After inserting 100 items,i am able to see the items.
whether i need to set any attributes????
Harika
(3,919 Views)
Are you processing at least draw events while you are adding elements to the listbox? If you aren't, then you won't see the listbox updating.
(3,916 Views)
