LabWindows/CVI
how to make run time error in a callback
Assuming a main rountine execute RunUserInterface.
How to make a run time error in one of the Interface callback routines?
Rafi
(3,181 Views)
If this is for your own validation, then you can pop up an error dialog. Something like MessagePopup() for example would work.
Bilal Durrani
NI
(3,183 Views)
If your problem is how to catch runtime errors, correctly react to them and warn the operator, you may look at errChk and nullChk macros: they are defined in toolbox.h and extensively used in the Programmer's Toolbox that comes with CVI.
To make these macros more useful and general use, I made some additions to them and developed another set of macros which are described in this thread: inside it there is also a small routine that uses a MessagePopup to warn the operator of the problem occurred as Bilal suggested.
Remember that your routine will be blocked waiting for input when the popup message is shown, so I reccommend you emit the popup after the proper countermeasures are taken to correct the error.
(3,173 Views)
Thanks Roberto and Billal,
I can see how I jump to an error routing and print messages.  However, I'm aiming more towards a situation where the program is running under TestStand.  Usually I know how to create a run-time error so that TS displays a runtime error with some information.
In this particular case, I'm referring to a situation were CVI is running a window (for barcode input in this case...) and is executing callbacks.  How do I return the error back to TS and terminate the program?
Rafi
(3,153 Views)
Rafi,
You can perform the Execution.Terminate() method or Engine.TerminateAll(),
Use the TestError parameter to return any error back into your TestStand Step.
Regards
Ray Farmer
Regards
Ray Farmer
(3,140 Views)
