LabWindows/CVI
how to pad left zeros to a number
hi all
how to divide a number in two halves and pads zeros to the left of a number
(3,328 Views)
When you format a string from a number, you can pad it with zeroes for example with sprint (string, "%08d", number); this instructions creates a string of (at least) 8 characters padding with zeroes to the left if the number is lower than 99999999; if greater resulting string will be enlarged consequently.
Next you can use strncpy (or StringCopyMax) and strcpy to split the string in two substrings.
(3,316 Views)
