LabWindows/CVI
how to play waveform then pause and play another waveform
I have a program that plays two waveform. I would like to play the first waveform and then delay for a certain time and then play the second waveform. I have the code attached and it looks like two separate programs. The top program fetches for two frequencies from a spreadsheet and adds the two frequencies and plays it. I want the top program to play first and then pause for a certain time and then play the second program with the case structure. Any help would be greatly appreciated.
Thanks a lot
(3,051 Views)
Since this question is related to LabVIEW you should post it to the appropriate forum
(3,043 Views)
Oli,
I've answered your question in this forum, http://forums.ni.com/ni/board/message?board.id=180&message.id=39333&jump=true.
Steven Zittrower
http://www.ni.com/support
(3,027 Views)
