LabWindows/CVI
how to relink logs that is marked as deleted?
As i move one project in labview signal express to a new computer it s a number of logs that are misslinked in the project. "the project that you just opened contains logs which are linked to the following deleted files. you need to restore these files in order for this project to work correctly"
how do i change directives for these logs?
(2,963 Views)
You have posted this in the LabWindows section.  You might get more responses if you post it in the LabView section.
(2,948 Views)
