LabWindows/CVI
how to specify domain name when using FTP library
I'm using the INET FTP library to try and connect to an FTP server.
How do I specify a domain name for both the server and/or username?
I'm using InetFTPLogin.
Menchar
(3,487 Views)
hehe, I hope I know that and help you out.
(3,479 Views)
Hi Menchar,
I'm not quite sure if I'm understanding you correctly. When using the InetFTPLogin command, you should be able to enter the domain name directly as the server name. For instance, you could enter "mysite.com" as my FTP server and add your username and password and you should be able to connect to your ftp server.
I'm not sure what version of CVI you are using, but there is an example program in both CVI 7.1 and 8.0 that shows the use of the InetFTP commands. It is under <CVI>\samples\internet\ftpcInt where <CVI> is the directory where CVI is installed.
If this example doesn't get you the information you need, just post back with further questions and I'll be glad to help you out.
Matt
(3,451 Views)
Matt -
Thanks for the reply.
We figured this out - Windows DNS was able to find the server based on the server name alone.
Menchar
(3,427 Views)
