LabWindows/CVI
how to turn off the "redeclaration" error?
I can't seem to get rid of the redeclaration error. Is there some way I can turn off the compiler from giving me this error?
(14,441 Views)
The redeclaration errors can be a pain sometimes, but you really shouldn't turn off checking for them, even if you could. They're there to make sure you don't change the declaration of a variable (etc.) in the middle of your program.
You need to find the source of the problem. It can be due to multiple C files using the same header files (depending on how they call each other's functions) or due to the same variables, constants, or functions being declared in multiple .h or .c files.
Do a search across multiple files for whatever is being redeclared.
If the problem is that multiple files are using the same .h file, you can fix that by making all declarations conditional so they get declared only once. Define a constant in your .h file to indicate that it has been read
by the compiler. At the top of the .h file, check if that constant has been defined before declaring anything.
For example:
#ifndef MY_FILE1_DECLARES_READ
#define MY_FILE1_DECLARES_READ
// insert all your declares here
#endif
This way, all your declares will be read only once. Note that the constant (MY_FILE1_DECLARES_READ in this example) needs to have a name unique across all .h files.
Sometimes, the order of the .h files makes a difference, especially if you're using some CVI standard headers and some Windows SDK headers. Some headers test for the existance of constants before declaring their own. Play with the order to see if that helps.
(14,441 Views)
I met the same problem,but it is still not ok when I defined a constant in the .h file like this:
#ifndef PHTEDTYPEDEFS_H
#define PHTEDTYPEDEFS_H
#endif
the error are below:
 API_Ted.c - 2 errors
 "phTedTypeDefs.h"(40,35)   Redeclaration of 'uint32_t'.
 "phTedTypeDefs.h"(58,30)   Redeclaration of 'int32_t'.
DRV_HiT.c - 2 errors
DRV_HiTa.c - 2 errors
DRV_Ted.c - 2 errors
TED_2.c - 2 errors
(13,911 Views)
Anyone can help me? Im a CVI beginner.
I inluded a .h file (PHTEDTYPEDEFS.H)
#ifdef __GNUG__
#include <stdint.h>
#include <cstddef>
#else
   * \addtogroup GlobalHeaders
  /* unsigned types */
  #ifndef __uint8_t_defined
  #define __uint8_t_defined
typedef unsigned long   uint32_t;
  #endif
#endif /* PHTEDTYPEDEFS_H */
but the stdint.h
define the
 typedef unsigned int        uint32_t;
so the error is  "phTedTypeDefs.h"(40,35)   Redeclaration of 'uint32_t'.
how s
(13,873 Views)
See my response to your other post.
http://forums.ni.com/t5/LabWindows-CVI/typedef-unsigned-long-long-UINT64/td-p/789580
A unsigned long and an unsigned int are the same thing in CVI. You could modify the header for the 3rd party DLL to use unsigned int.
(13,848 Views)
(13,847 Views)
Hi ,
thank you very much,
I think i have no other choice but to change the 3rd party header files,yes,it is okay,after i have change the 3rd pary files, there are so many files  which were included in my souce code i have to update,maybe this is not good way .~~
(13,841 Views)
