LabWindows/CVI
how to use a dll which export a function with uncertainty parameters
I have created a dll in labwindowscvi5.0.1,the export function of dll has several uncertainty parameters(I mean these parameters will be given value at the time other program use the dll,for example:function(channel,gain)).Now I will use the dll in vc++6.0,I want to pass value to the parameters of export function of dll in vc++6.0,and run my program to get result.But I don't know how to do it in vc++6.0,I need a sample.I look for the sample in your resource library,but only find a sample dll which export a function(void).If you know,please tell me.
thanks
(2,885 Views)
Hey there -
I think you just want to call a dll created in CVI from VC++? Correct? Calling a function from a dll with input arguments is very easy - you do not change the method of calling a dll, just call the dll as you normally would. For more help about dlls and VC++, check out http://msdn.microsoft.com/library/default.asp?URL=/library/psdk/winbase/dll_512r.htm
It is a page that describes dlls in Microsoft and how to use them in VC++.
Check out the attached example, it calls a dll made in CVI from VC++, among other things.
Good luck -
ben schulte
national instruments
(2,885 Views)
