LabWindows/CVI
how to use installpopup in multithreading?
i build a new thread in my test program,in this program i a installpopup to show a PANEL,when this panel is displayed the test must stop,and when this panel is closed,the test is go on.so when the panel display i want the pre-panel no used,but when i write below code,this cann't realised,can you tell me the reason? and what can i do?
static int cvicallback testthread (void *functionData)
//thread of test
hanel=LoadPanel (0, "panels.uir", PANEL);
while(true)
procedure1();
void procedure1(void)
InstallPopup(handel);
RunUserInterface();
(2,875 Views)
You are calling RunUserInterface inside your procedure1() function, but I assume the user interface was already started before the testthread() function was called. You don't need to execute RunUserInterface more than once in your program; moreover, a second instance of the user interface can cause several unexpected behaviours. Try commenting out this line and see if all works well this way.
Roberto
(2,875 Views)
