LabWindows/CVI
how to write code for check sum and size i have 16x32 table..
(5,023 Views)
A1+...+A16 ?
(5,022 Views)
what?
(5,018 Views)
This is a basic misunderstanding...
This forum is mainly about questions about / problems encountered when using LabWIndows/CVI, but not about coding itself. So if you have a question specific to CVI this is the right place to ask.
Since checksums are frequently encountered in data acquisition this topic is covered here as well, but you can and should use the search function of this forum first. You then will find several posts on this subject, e.g. here and here, so why not search (and read) first, try to implement the answers yourself, and then ask if it turns out that CVI reports an error?
(5,014 Views)
Additionally, is not a good practice to open two threads on the very same issue! This discussion started here and could have been kept there. Smiley Indifferent
But anyway, let's continue in this thread.
I have little to add to wolfgang answer, except that you must have clear which checksum you want to compute Smiley Surprised As you can see here, there is not a unique definition of "checksum".
(5,004 Views)
