LabWindows/CVI
how to write int. and char data in to a text file in CVI?
I am having trouble writing data to text file in CVI. All I want is to be able to enter data from Panel and write to a text file. I am just not sure my parameter should be. Any help?
(4,887 Views)
Have you looked at the WriteFile function? Here's the documentation for that function:
This function writes the specified number of bytes to a file from a string buffer.
CAUTION: The Windows SDK also contains a WriteFile function. If you include windows.h and do not include formatio.h, you will get compile errors if you call the WriteFile function.
/*-------------------- Prototype ---------------------*/
int WriteFile (int File_Handle, char Buffer[], int Count);
Or, if you are writing an array to a file, I would suggest the ArrayToFile function. There is a good example program in CVI under Fundamentals >> File Input and Output >> arrayfile.prj that demonstrates this function.
Note that if you right-click on any function panel, the Funct
ion Help is automatically displayed for that function. The same is true if you right-click on a particular control input.
Good luck!
Kileen C.
(4,887 Views)
You can also use the ANSI C fprintf() function if you want to create your own formatting and delimiters. For example:
#include
int myInt;
char myString[256];
FILE *myFile;
/* you'll call GetCtrlVal() instead of the next two assignment statements */
myInt = 256;
strcpy (myString, "Hello world!");
myFile = fopen ("eraseme.txt", "w");
fprintf (myFile, "%d\t%s\n", myInt, myString);
fclose (myFile);
(4,887 Views)
You may also want to look at the example installed at C:\Program Files\National Instruments\CVI70\samples\fileio . It's a good example for ASCI and binary data.
Just my 2 cents.
Juan Carlos
N.I.
(4,887 Views)
Thanks a bunch for your input. I did get an idea for I wanted to do from this example.
Thanks again!
(4,887 Views)
