LabWindows/CVI
i want to programtically obtain each column in table of a panel
hi everyone:
i want to  programtically obtain each column in table of a panel, and i would like to use a loop statement to change each column label text name automatically?
(2,862 Views)
This can be accomplished with a loop that iterates from 1 to the number of columns in the table and uses SetTableColumnAttribute (panelHandle, tableID, colIdx, ATTR_LABEL_TEXT, "Lable"); to set the label text. The label will be displayed only for each column on which you have choosed at design time to display a lable text instead of the default index value. This option can be set even at runtime passing the appropriate attribute to SetTableColumnAttribute (ATTR_USE_LABEL_TEXT).
GetNumTableColumns function retrieves the number of existing columns in a table.
(2,860 Views)
