LabWindows/CVI
iberr == 6(0x6) when using ibwrt()
I am trying to send some commands via GPIB and when I try to use ibwrt(), it gives my the following error: ibwrt: (iberr == 6(0x6)). I used this command multiple times before I got this error, i.e. I was wrting to the instrument correctly more than 10 times before and then I got this error randomly. Am I missing something, like clearing the queu or some thing like that?
(4,339 Views)
I resolved this issue by changing the GPIB timeout to a higher value. Use ibtmo (int ud, int v) command to change the timeout.
(4,330 Views)
I'm having the same problem, and it will help me a lot if you can explain and detail the way you fixed your issue. I'm not very used to working on LabWindows
Thanks!
(3,596 Views)
I found how to do this but it does'nt fix my problem... 😞
(3,580 Views)
