LabWindows/CVI
illegal use of type name
Hi, C++ guy trying to write C code for LabWindows/CVI, having some trouble with struct declaration/usage. The following code compiles and runs fine: (I'm aware there are existing Point typedefs, this is a contrived example of a problem I'm having with my struct usage in general)
#include <formatio.h>
#include <ansi_c.h>
typedef struct {
    int x;
    int y;
} Point2D;
int display(Point2D p);
int main(int argc, char *argv[])
    Point2D a;
    a.x = 1;
    a.y = 0;
    display(a);
    return 0;
    char msg[64];
    Fmt (msg, "%s<%s%i%s%i", "x= ", p.x, ", y= ", p.y);
    printf(msg);
    return 0;
The following code gives a compile error: "20, 5 Illegal use of type name 'Point2D'."
#include <ansi_c.h>
typedef struct {
    int x;
    int y;
} Point2D;
    Point2D a;
    a.x = 1;
    a.y = 0;
    display(a);
    Point2D b;
    b.x = 2;
    b.y = 0;
    display(b);
    return 0;
    char msg[64];
    printf(msg);
    return 0;
Why can't I instance another Point2D called b? Thanks!
(5,537 Views)
Move the declaration for b under the declaration for a.  C does not allow you declare variables in the middle of your code segment like you can in C++.
    Point2D a;
    Point2D b;
    a.x = 1;
    a.y = 0;
    display(a);
    b.x = 2;
 should work
Message Edited by mvr on 06-14-2007 01:18 PM
(5,538 Views)
Awesome, thanks!
(5,532 Views)
For what it is worth you can define a variable in a local code block that has a scope only within that block.
Int func(void)
int a;
a=0;
printf("a=%d\r\n", a);
{  // local block
   int b;
   b=20;
   printf("b=%d\r\n", b);
return a;
Can be useful when doing things in a more C++ like style.
OT: I have no idea what causes the double spacing of lines in reply messages.
Message Edited by mvr on 06-14-2007 01:26 PM
(5,533 Views)
Ah I see, thanks. I'll just get into the habit of declaring everything together at the top of my functions.
(5,525 Views)
