LabWindows/CVI
imaqLearnPattern
Hi. I am trying to select a part of an image ( video ) and display it a new window in order to search it in video image.
After i open the camera a new window pops up to see the video image than i choose a part of it with toolbox than a new window pops up but instead of the part of the image i see green image at the size of the part that i chose.
/* Create images that will be used within this program */
            searchImage = imaqCreateImage (IMAQ_IMAGE_RGB, 2);
            templateImage = imaqCreateImage (IMAQ_IMAGE_RGB, 2);
        etc. etc. etc. etc.
            switch (event)
                        case IMAQ_DRAW_EVENT:
                                    userRect = rect;
                                    imaqSetImageSize(templateImage, userRect.width, userRect.height);
                                    imaqCopyRect (templateImage, searchImage, userRect,
        imaqMakePoint(0,0));
                                    imaqMoveWindow (1, MakePoint(410,350));
                                    imaqDisplayImage (templateImage, 1, 1);
                                    break;
 Please help.
(3,635 Views)
Hello ReuvenGershon,
If I interpret you correctly you are acquiring video from a camera, and you want to crop out a certain portion of the image leaving only a specified rectangle of the orignal image behind.  Is this correct?  If so, I'm uncertain which portion you are having difficulty with.  Does the code you post produce a green image that isn't supposed to be green?  Or does it not resize the image as it is intended to be resized?
David A
(3,614 Views)
Thanks for reply.
You are right. The thing is i want to choose an object and track it ; lets say ball. Size of the image correct but it always pop up in green. Doesn't matter what i chose it is always green.
(3,610 Views)
It looks like this is a duplicate thread.  I've spoken with Michael B. and we've decided to close this thread and post responses in the other thread.
David A.
(3,578 Views)
