LabWindows/CVI
imaqOpenAVI Hang
Any thoughts as to why imaqopenAVI() may hang?  I'm having a problem where an application is hanging on this function call on a deployed PC.  The PC is running Windows 7 32-bit, Vision 2011-03 (updated to 2012-08 with no change).  Same application running different PCs (XP, Win 7 32-bit, Win 7 64-bit) seems to be able to open the same .avi file just fine.  The application was built using CVI 2012, on Windows XP, with NI-IMAQ 4.3 installed.  The .avi file was generated using the NI imaq functions.  I'm assuming it's some configuration problem or similar?  Thanks.
(3,592 Views)
Accepted by topic author tstanley
I figured it out.  It ended up being a problem with ffdshow on the target computer.  All is good now!  Smiley Happy
(3,588 Views)
