LabWindows/CVI
immovable window in LabWindows CVI
I have this little window on my desktop whenever I run CVI (I'm using 8.5.1),
closing this window closes CVI,
the window is not movable.
Not a big deal, just unnecessary clutter.
(3,976 Views)
Hey Ken,
I know you said you couldn't move the window, but can you resize it? It would be nice to see the title bar. Hopefully that will point us in the right direction. Also, if you cannot resize the window, could you post a small example that demonstrates the behavior? Thanks!
Matt S
(3,918 Views)
Acutally, that window is expected, but is usually hidden offscreen. See this thread for a detailed discussion.
Mert A.
(3,906 Views)
It would not resize.
I am testing with one of the samples, and I get this panel:
C:\Documents and Settings\All Users\Documents\National Instruments\CVI\samples\nican\Frame API\Transmit Receive same Port
and I running this in debug mode.
Message Edited by Ken (This is my stinking alias) on 09-08-2008 01:21 PM
(3,905 Views)
Wow. Crazy, but I made the change;
disabling "Prevent windows from opening off-screen" and the box is gone (per the referenced thread).
But, the reason I enabled that was due to undocking my laptop (which has dual screens when docked) and having windows open on the now missing screen. There seems no way to then move those to the active screen, so I NEED to have this enabled.
(3,899 Views)
