LabWindows/CVI
in bar graph how should we get name of diminsion on perticular bar in labwindow/CVI ?
(4,128 Views)
Can you explain your question a bit more? Can you add an example of what you want to obtain?
(4,114 Views)
I guess that you need to get the names of X and Y axis ?
So you must use GetCtrlAttribute function, as shown below :
char xAxisName[32];
char yAxisName[32];
GetCtrlAttribute (panelHandle, PANEL_BARGRAPH, ATTR_XNAME, xAxisName);
GetCtrlAttribute (panelHandle, PANEL_BARGRAPH, ATTR_YNAME, yAxisName);
(4,100 Views)
Here is a screenshot, to make it clear if needed... 🙂
(4,098 Views)
