LabWindows/CVI
index passed is out of range
I think I encountered a bug in UIR editor (CVI 8.5.1):
If you place a control with a label on a panel, then you select the label only and press Shift+F10 you edit only the coordinates of the label. That's OK upto here.
If you place the same control on a tab page and try to edit the coordinates of the only I get a small error popup saying "The index passed is out range."
I tried it with multiple types of controls and the behaviour is the same.
Can anyone repeat this behaviour on your computer?
S. Eren BALCI
IMESTEK
(3,450 Views)
Hello ebalci,
Thanks for reporting this. I've recorded it as a bug (#140209).
Luis
(3,436 Views)
