LabWindows/CVI
inifile : strange behaviour : CVI7
I'm surprised to see that ReadFromFile seems to sort items for sections.For example,
[Section]
0x0B = TEST1
0x0A = Test2
If I get items one by one with Ini_NthItemName(i).The first is 0x0A not 0x0B !. So, it seems like IniFile.Fp sort the items even if I uses Ini_DisableSort(). Why ?
(3,582 Views)
I couldn't reproduce this. When you create the ini file with INI_New(0), it shouldn't auto-sort when you read. I also tested creating with Ini_New(1), then calling Ini_DisableSort() BEFORE calling Ini_ReadFromFile and it also did not auto-sort. So both code examples below, didn't sort the list in memory.
g_myInifile = Ini_New (0);
Ini_ReadFromFile (g_myInifile, g_fileName);
or
g_myInifile = Ini_New (1);
Ini_DisableSort(g_myIniFile);
Best Regards,
Chris Matthews
(3,582 Views)
Thank you.
I didn't sort the inifile inside my project but you're right, in another very simple application it works fine. I will searched again what happends.
I've noticed that localui.fp automatically load inifile.fp, so it's not necessary to add it n the project.Is it true ?
(3,582 Views)
That's true. However, we provide the source code of inifile.fp (inifile.c) for you, in case you need or want to modify or debug it, so it may help to add the inifile.c file to your project so you can step through the inifile code and see what is going on.
Chris
(3,582 Views)
OK.I've found the trouble.It comes from my application.
Thank you.
(3,582 Views)
