LabWindows/CVI
interface not registered
When I tried to write data using datasocket, there is an error while debugging the line:
DS_Open (URL, DSConst_Write, UpdateDSCallback, NULL, &DSWriteHandle);
The error is:
Function DS_open:(return value==-2147221163[0x80040155]).interface not registered.
What should I do to slove the problem. Also, I am not clear of how to set up the URL. Does one file folder should be contained in it? All suggestions are appreciated.
(3,309 Views)
Hi sinaco,
If you look at the  CVI help for the DS_Open function, it will give you a description of how the URL should be formatted, as well as several example URLs that you can look at.  One test that I would encourage you to try is running datasocket example programs that ship with CVI to ensure that these work without error.  These sample programs are in the C:\Program Files\National Instruments\CVIxx\samples\datasocket folder.
Additionally, you may want to look at using network variables.  Sample programs can be seen in C:\Program Files\National Instruments\CVIxx\samples\networvariable.
Cheers,
Kelly R.
(3,275 Views)
