LabWindows/CVI
is RegExpr FP thread safe?
Are the regular expression functions in the regexpr.fp thread safe?
Menchar
(4,146 Views)
Hi Menchar,
Those functions are not thread safe; the header file (regexpr.h) includes a warning at the top of the file that mentions this. Hope this answers your question.
Ebele O.
(4,121 Views)
Ebele -
Thanks for the info.
It would be really cool if the CVI regular expression code were thread safe and could parse across a newline character.
Menchar
(4,113 Views)
Actually, if you have CVI 8.0 or higher then this code is thread-safe. The comments are obsolete and should (will) be removed in the next release. You can verify if the code was made thread safe by looking at regexpr.c - you should see calls to GetLock, etc.
(4,099 Views)
Thanks - I do see where it looks like it's set up to be threadsafe but when the comments say it's not (and the NI person says, "well, duh - read the comments") it makes one hesitate Smiley Wink  I thought maybe it was a work in progress or that it hadn't been checked out.  That's why I asked.
Now if they could get it to parse across a newline character  ...
Menchar
(4,089 Views)
