LabWindows/CVI
ivipower.h
I am currently looking at updating some Labwindows Test Software from NT to XP and downloaded the latest IVI Compliance Software (IVI CS) as the Test Software uses a TSP3222H Programmable PSU , and the driver I am using needs the IVI Software installed.  Now, I noticed that the old version of IVI CS uses the file IVIPOWER.H, but this does not exist in the latest version of IVI CS.  There is a file IVIDCPWR.H, which is similar, but the type definitions to not appear to match, which means the PSU driver will have to change to match the new defines.  So, does anyone understand what I am trying to say, and has anyone come across this before?
Cheers
Stu
(4,053 Views)
Do you still have access to the NT system?  This driver might have used IDT 1.0 that come with a much older version of ICP.
From the documentation for IDT 1.1 that references IDT 1.0:
        To preserve the IviPower class driver, copy the IVIPOWER.DLL file into the VXIPNP\Win95(or WinNT)\BIN directory.
(4,037 Views)
Hi Stu,
Just wondering how you got on with jjp377's advice?  If you hav enay further questions, please post back.
Sheela Sujeeun
National Instruments UK
(4,000 Views)
I just got back to looking at this problem today.......I got a copy of the ivipower.h file, copied it across to the XP system and this seems to work fine.  Thanks again for your help.
(3,991 Views)
Glad to hear you got it working 🙂
Sheela Sujeeun
(3,989 Views)
