LabWindows/CVI
je cherche un moyen pour sortir d'une boucle While a l'aide d'un bouton en face avant sous labwindows/CVI 6.0?
bonjour, j'ai cr" une boucle while infini dans ma face arriére .c et je voudrais pouvoire en sortir ou l'arréter avec un bouton placer sur ma face avant .uir
(2,862 Views)
(I apologize for answering in English. My French is barely good enough to read, impossible to write..)
The answer depends on whether you already have a User Interface panel in your program and how you are processing events for it. There are two possibilities:
Option 1 - RunUserInterface
Using this option, your program would look something like this:
main ()
panel = LoadPanel (...);
DisplayPanel (panel);
RunUserInterface();
int done = 0;
void YourFunc (void)
while (!done)
// do your work here
int ButtonCallback (int event, ...)
if (event == EVENT_COMMIT)
done = 1;
return 0;
If you use this option, you'll have to ass
ociate ButtonCallback with your button in the UI Editor.
Option 2 - GetUserEvent
int done = 0;
while (!done)
GetUserEvent (0, &panel, &control);
switch (control)
case PANEL_YOURBUTTON:
done = 1;
break;
I hope this makes sense. If you'd like test this, I'd suggest that you look through some of the simple example programs in samples\userint
Luis
NI
(2,862 Views)
