LabWindows/CVI
je cherche un moyen pour sortir d'une boucle While a l'aide d'un bouton en face avant sous labwindows/CVI 6.0?
bonjour, j'ai crée une boucle while infini dans ma face arriére .c et je voudrais pouvoire en sortir ou l'arréter avec un bouton placer sur ma face avant .uir . comment puis je faire?
(2,968 Views)
I hope I have correctly translated from french: you are looking for a way of exiting an infinite while loop by means of a button in the user interface.
You can obtain this using a common variable set to 0 before starting the while loop, raised to 1 in the button callback and used as an exit condition inside the loop. For this mechanism to work, you will need to add a ProcessSystemEvents () inside the loop, otherwise user interface events are not processed by the program while executing the loop.
I'm sorry but I'm not able to translate it in french: I hope this explanation is clear enough.
You can look at the attached project for an example.
Roberto
(2,968 Views)
