LabWindows/CVI
labview web server help
i want to build a labview server for remote monitoring of labview vi. can any body help???? i used web publishing tool of labview it gave me a url like
http://acer:8000/test14.html but this is not working on remote system.... ???? how can i access this adress from an other system...
(4,424 Views)
You're not on the appropriate forum. You should post your question in LabVIEW forum :
http://forums.ni.com/t5/LabVIEW/bd-p/170
So that you will be more likely to have an answer ! ^^
(4,415 Views)
