LabWindows/CVI
labwindows DAQ help
Hi, I am a Labwindows beginner. I know it is pretty easy to collect data using NI DAQ and Labview. But now I want to collect data using Labwindow. Could you tell me where to begin with. Any introduction manual or on line link will be helpful. By the way, if I use other DAQ hardware and no driver is available, how can I write the driver code? Sorry, I didn't find relevant instruction at your website.
(3,205 Views)
In my opinion you should study the examples that are installed in CVI together with NI-DAQ software or are available on NI site (a list can be found here and additional resources are listed here [broken links removed]): this collection of samples covers the main acquisition and generation tasks and that give you a framework from which to start developing your application.
I suggest you also to revise the knowledge base and tutorials that are available on the NI site and take a look at the contents published in the developer zone: here the result of search for tutorial, data acquisition and cvi .
(3,199 Views)
