LabWindows/CVI
labwindows_chart_help
Hello i I'm using LabWindows CVI ver. 5.0...
I'm developing excel application,I have transferred 2 data arrays to excel and made chart...
But my chart format isn't like a line format 😞
here is my code :
            Excel_ChartChartWizard (ExcelChartsHandle, NULL,
                                    CA_VariantDispatch (GrafikSINIR),
                                    CA_VariantInt(ExcelConst_xlLine),
                                    CA_DEFAULT_VAL,
                                    CA_VariantInt(ExcelConst_xlColumns),
                                    CA_DEFAULT_VAL, CA_DEFAULT_VAL,
                                    CA_DEFAULT_VAL, MyVariant, CA_DEFAULT_VAL,
                                    CA_DEFAULT_VAL, CA_DEFAULT_VAL);
how can fix my problem?
thanx your suggestions...
and I tried attach two pictures lots of times but couldn't.
(3,383 Views)
Hi anatolia,
If your Excel uses the same prototype that mine does, you can change the "gallery" parameter to "xLine".  Here is a link that explains where your version of Excel's help is, if it's installed, so you can check the possible parameter values of your Excel's ChartWizard function.
http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q222101&
Gavin Fox
Systems Software
(3,364 Views)
Thanks a lot, I solved my problem...
I have written a macro in excel like that :
    Sub Line_Chart()
    With Worksheets(1).ChartObjects(1).Chart
        .ChartType = xlLine
    End With
    End Sub
This  macro  changes  the  chart  type  as  line.Then  I have written like this code in LabWindowsCVI to run my macro :
 static VARIANT    YAZI;
            CA_VariantClear(&YAZI);
            CA_VariantSetCString (&YAZI, "sabit.xls!Sayfa1.Line_Chart");                             /*  this is name of the macro */
            Excel_AppRun (ExcelAppHandle, NULL, YAZI, CA_DEFAULT_VAL,
                          CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL,
                          CA_DEFAULT_VAL, CA_DEFAULT_VAL, NULL);
This is my solution,
but I'm sure that, in somewhere there is a better method than mineSmiley Wink
Message Edited by anatolia_levent on 02-19-2007 12:34 PM
(3,337 Views)
