LabWindows/CVI
labwindows cvi textbox
I worked with textbox and I got an erros such as: the control passed is not a textbox, but I passed the correct control!! How is it possible???
(7,027 Views)
It's not easy to try guessing what's happening with so few elements.
Can you give us some more details: which CVI version are you using, which OS, an abstract of your code, a sample panel...?
Message Edited by Roberto Bozzolo on 02-06-2009 09:34 PM
(7,020 Views)
Just a guess:
If your textbox is inside a tab page then you should call GetPanelHandleFromTabPage first to get a handle and use that handle for SetCtrlVal and other similar functions as the first parameter.
Hope this solves your problem.
S. Eren BALCI
IMESTEK
(7,006 Views)
I have the version of the program 7.1. I've created a panel, and I took from a list the string of char that I want to put in the text box that is in another panel. I took the string with GetLabelFromIndex and I have the string in a variable "patname". So now I have to put this string of char in a textbox, but i can't use setctrlvalue becouse it doesn't work with char!! How can I put the string in the text box??? I tried with: InsertTextBoxLine but there is an error : "the control passed is not a text box". But the control that i passed is a textbox!! How can it be possible?? Thank you for your answer! kisses
(6,980 Views)
Accepted by topic author Nicla-
Hi Nicla,
SetCtrlVal function actually works with character strings. You can write:
char path[256];
GetLabelFromIndex (panel1, PANEL1_LIST, index, path);
SetCtrlVal (panel2, PANEL2_TEXTBOX, path);
Besides, I doubt that you are confusing a 'string control' with a 'textbox control'. A string control is single line box in which you can type/display a pathname or any other string.
A textbox can be multiline with scroll bars, etc.
You cannot be blamed for this. Because the term "textbox" is also used as a name for the general single line version (which NI calls a string control) by the computer users.
Anyway, you should be able to use SetCtrlVal for both string and textbox type of controls.
Hope this helps,
S. Eren BALCI
IMESTEK
(6,973 Views)
thank you!!!!! Smiley Happy
(6,967 Views)
This is a very simple question, but I have not been able to learn the answer. What is the max # of character a textbox can hold? When this # is exceeded what is the error generated?
(6,046 Views)
