LabWindows/CVI
labwindows/cvi version 5 compatibility
Is labwindows/cvi version 5 compatible with PCCI-6221 M Series data acquisition device on windows xp.If not which version should be used?
(3,381 Views)
Hi Faez,
LabWindows CVI 5 is only supported under Windows 95/NT, Windows 3.0 and UNIX. If you want to use CVI with Windows XP and the PCI-6221 I would recommend upgrading to CVI 2009. Please get in contact with your local NI Branch to discus this further.
Best wishes,
Ben L
Field Engineer
(3,340 Views)
