LabWindows/CVI
library error language selection
Hi all,
how can I select the language of error messages resulting from library calls like TCP support library or UDP support library or ... ?
Thanking you in anticipation.
(3,352 Views)
Accepted by topic author JensT
Hi Yeti0815,
the messages of the prompt errors are in english, because the help and error explanations are in this language.
If you want other messages you can implement your own failure handling.
If you have more questions, please let me know
best regards
Alexander
(3,329 Views)
