LabWindows/CVI
linker error - I cannot find the symbol
I get several linker errors in my project as follows...
"Undefined symbol '_error_message' referenced in hp662x.c"
The source code is included in the project file.  However, I cannot find the reference it's complaining about "_error_message".  It's nowhere to be found in the code base.
Any ideas?  I've been at this same bug for about 4 hours now.
Thanks!
(3,965 Views)
a quick search on google yields me on this
http://www.home.agilent.com/upload/cmc_upload/All/vxipnp_662x_b_00_01.html
on item 3.3, i don't know if it s relevant or not.
(3,954 Views)
Yeah I had seen this article too.  However, when I follow the instructions, include just the .fp file along with (or even without) the .h file, the same linker errors appear.  I tried doing the straight forward version as well with the .h and .c files but still no dice.  Thought perhaps my driver was corrupt but a new one is no where to be found, I spent a good hour or two surfing the web for one.
I really appreciate the help!  I'm completely stumped here and have to figure it out.
(3,943 Views)
You said you 'included' the fp file - I take it you actually went through the CVI process of adding the fp instrument file to the project, and not just literally including the file? Was there not a .lib file as well as the .dll in the supplied files?
JR
(3,933 Views)
JR
I'm not sure what you mean by CVI process of adding an fp insturment.  I'm fairly new to LabWindows.  I had added the .fp file to the project and included the associated .h file.  Is there something more to building with an .fp?
I actually think my underlying issue is somewhere someplace I'm missing a file.  However, I'm having difficulty finding a fresh copy of the instrument driver.  It's a Agilent 6622a power supply but apparently agilent doesn't supply drivers for it anymore?
http://www.home.agilent.com/agilent/techSupport.jspx?pid=836779&pageMode=DS&cc=US&lc=eng
(3,930 Views)
goodnufcode:
Here's a link to the drivers for the 6623A power supply.
http://www.home.agilent.com/agilent/facet.jspx?t=80045.k.1&ki[0]=6623&cc=US&lc=eng&sm=g
When you added the .fp file to your project, did you copy the .fp file or leave it in its original location under C:\VXIpnp ?
Try building the attached project.  Note that it doesn't really do anything: I just threw it together to test linking to hp662x.fp
(3,912 Views)
