LabWindows/CVI
linking issue, undefined symbol on .obj
I am trying to compile some software that was written by another person in our company.  I am having trouble linking the software, and am getting the following errors:
  Undefined symbol '_MessagePopup@8' referenced in "asynctmr.obj".
  Undefined symbol '_GetCurrentPlatform@0' referenced in "asynctmr.obj".
The asynctmr.fp is listed in my included instrument files, but am not really sure what I am missing.
(5,190 Views)
It appears that the issue is that I have the build options set to "Real-time" only and the runtime support for the above functions are not getting included.   This application will run on NI RTOS, so i can not check the "Run-time."
I know it must be possible to use the asyncronous timers and the RTOS, as it ran on a previous computer, but I am not sure how to get around this.
(5,160 Views)
Hi jebeyers,
We added Asynchronous Timer support to RT applications in CVI 8.1.  What version of CVI do you have?
Best Regards,
Message Edited by Jonathan N on 06-27-2007 12:24 PM
Jonathan N.
(5,161 Views)
Hi jbeyers,
Did somebody happen to edit the default asynchronous timer instrument driver? The reason I ask is that the source file for that .obj file doesn't contain references to those functions you mentioned? Plus, those functions are not even supported on Real-Time which makes me even more confused. Going even further, if for example you tried to build a DLL that was targeted for RT that included a non-supported function (i.e. like MessagePopup), you will get a message like "Undefined symbol '_MessagePopup@8' referenced in "Real-Time Target Application.c".
Any thoughts??
Best Regards,
Message Edited by Jonathan N on 06-27-2007 12:34 PM
Jonathan N.
(5,157 Views)
I upgraded to CVI8.1 and all linking problems were solved.
(5,137 Views)
