LabWindows/CVI
linking problem betn two C Files
I face a linker problem in my program .Here I have 2 .C files betn these two one contains main() function . Now I call a user defined function from main () .The function body i.e definition is in second C file but declaration is in first .C file . During run time its giving "Multiply symbol
 _X in A.c and B.c ". Where X =Name of the user-defined function .
                                             A.c & B.c are two C Files .
Please reply whats wrong and how to recover from this problem ?
subrata
(3,139 Views)
The problems you are seeing derive on the function being defined in both C files: the compiler detects this conditions and raises an error.
You must change the declaration in the source file with main () function to be a referencing declaration by adding the extern keyword.
(3,129 Views)
