LabWindows/CVI
linking problems while compiling using mingw
Thanks to several tricks, I have managed to make CVI use mingw as an external compiler on CVI 8.5.0.
I still have some troubles that I can bypass, but I would like to understand why do I need to do things the way I'm doing it.
There are 2 linking problems. Here are the original messages:
  Undefined symbol '___chkstk_ms' referenced in "some_file.c".
  Undefined symbol '___main' referenced in "Main.c".
Concerning the first one, the only way I found to avoid the problem is to use "-mno-stack-arg-probe" when compiling using mingw.
Suprisingly, I haven't found any other way such as adding some .lib (or .a because of mingw). Maybe I have done something wrong but I just don't get it.
Concerning the second problem, the only way I found (thanks to many searches with google) to avoid the problem is to define such a function:
int __main(void) { return 0; }
This one is totally mysterious to me...
I know that mingw is not supposed to be a supported compiler (I will make another thread to explain how I managed to use it), but I want to understand my quite stange (at least, to me) linking problems.
If any CVI guru can give me some links/explanation, I would be grateful.
Most likely, I will also ask similar questions to some gcc/mingw guru, but let's try here first. 🙂
Please note that these problems only occur if I do the linking in the CVI IDE (for practical reasons, this is my prefered way). If I build a separate project in CodeBlocks for instance, the linking goes fine.
This is why I do suspect some incompatibility between mingw compiler and CVI linker.
Frédéric Lochon.
(4,314 Views)
(4,291 Views)
Hello Frédéric,
You just said that you can compile with MinGW and link with CodeBlocks. Well this is exactly what I looking for but I keep geting 'undefined references' at compile time on the trial functions I am trying to use. I use MinGW 4.8.1 and CodeBlocks 16.01. Can you send the some more info on this subject ?
GPinto
(3,403 Views)
