LabWindows/CVI
list box index
In the code below I am trying to get the proper iItem in from the control when I single left click on it. There seems to be a delay. ie I left click once, and I get the previous iItem. then I need to left click again (note not double left).
Please tell me what I am doing wrong.
case EVENT_LEFT_CLICK:
SetCtrlAttribute (panelHandle, PANELSCRIP_WEIGHT, ATTR_DIMMED, 0);
iRc=GetCtrlIndex (panelHandle, PANELSCRIP_LISTBOX, &iItem);
iRc=GetLabelFromIndex (panelHandle, PANELSCRIP_LISTBOX, iItem, szValue);
szValue[4]='\0';
iRc = Ini_GetInt (itHandle, "Weights", szValue, &iInt);
if (iRc>0)
SetCtrlVal (panelHandle, PANELSCRIP_WEIGHT, iInt);
else
SetCtrlVal (panelHandle, PANELSCRIP_WEIGHT, 0);
break;
(3,721 Views)
This behaviour depends on the order on which control events are processed.
Click events on a control are processed before the control changes its value (in case of a list: moves the selecting line), so GetCtrlIndex correctly returns the old selected item index.
To obtain the new item index you must move your code to EVENT_VAL_CHANGED event. Strange enough, the event is triggered even if values associated to the list items are the same: in this case the event seems to be related to the control's index rather then its value.
In case you cannot use EVENT_VAL_CHANGED event, you could use a postdeferred callback to process the event:
In the list callback add these lines:
if (event == EVENT_LEFT_CLICK) {
PostDeferredCall (IndexFunct, 0);
return 0;
The post deferred callback:
void CVICALLBACK IndexFunct (void *callbackData)
int i;
char msg[32];
GetCtrlIndex (mainH, Main_lista, &i);
sprintf (msg, "Item index %d.", i);
MessagePopup ("Index", msg);
return;
Remember that in this case the postdeferred callback is processed after all control events, so you may need to adapt your code.
Hope this helps
Roberto
(3,721 Views)
Roberto, thanks. I have one more issue with it. I have a numeric control on the panel that I have dimmed initially. When a user clicks on any of the the list items, I want to undim it. Now when the list box first comes up, there is a dotted line around the first item. This is fine. Then the user clicks on this first item, and I want the numeric to undim. I have code in
case EVENT_COMMIT:
break;
to undim it. This seems to work fine if the user picks any of the list items except the first one with the dotted lines.
(3,721 Views)
You've put the undim code in the EVENT_COMMIT of the listbox. Assuming the listbox is not in check mode, commit events are only sent to the callback whenever the user presses the key, or double-clicks on the listbox. From your description, it doesn't seem as if that is what you want. It seems that you'd want to do it on the LEFT_CLICK event, or if that's overkill, maybe on the GOT_FOCUS event.
You should look at the behavior of the listbox events in the user interface editor (switch to operate mode, and look at the top-right corner of the window) to pick the one that best matches your objectives.
Luis
NI
(3,721 Views)
