LabWindows/CVI
localui update lwl
Using labwindows CVI2015, I have tried the localization localui.fp and the associated localui.exe utility.
It works one time for creating the translation of my labels. But then if the content of the .UI file changes, I cant load it anymore to update the list of labels.
Any idea would help.
Serge
(1,387 Views)
You should be able to run the utility again and reload the localization file ( .lwl) so that existing translations are applied to the UIR objects. Next you can modify existing translations or add some element more and resave the .lwl file.
Are you finding some problem in this process?
Additionally you can create a dictionary file (.lwd) that can be applied to every UIR file so that recurring elements are automatically translated without need to do this job again and again.
(1,362 Views)
