LabWindows/CVI
log file function combining DebugPrintf and fprintf with varargin
I want to combine DebugPrintf and fprintf into one function, say LogPrintf. The idea is that everywhere in my code that I use a DebugPrintf I could also be fprintf'ing to a log file.
Suppose my code says this:
int i = 0;
DebugPrintf("%s%d\n", "Hello world. Counter = ", i);
Instead I want to have it say:
int i = 0;
LogPrintf("%s%d\n", "Hello world. Counter = ", i);
The interface to LogPrintf would be exactly like the interface to DebugPrintf:
int LogPrintf (const char formatString[], ...);
Then within LogPrintf, and assuming I've already opened the log file to use for fprintf, I would put:
DebugPrintf(input formatting string, input arguments list);
fprintf(already opened log file pointer, input formatting string, input arguments list);
My problem is with the varargin (...) in the argument lists of DebugPrintf and fprintf. How do I pass the variable-length argument list as a parameter into the DebugPrintf and fprintf calls within LogPrintf ?
Any ideas?
Thanks!
(5,135 Views)
Are you looking for something like this?
int LogPrintf(char *format, ...)
{  va_list arguments;
 va_start(arguments, format);
 fprintf(logFileStream, format, arguments);
 va_end(arguments);
 return(0);
(5,133 Views)
Thanks, this got me started! One problem is you can't pass format and arguments directly to fprintf like you suggested.
But I found some ANSI C functions that might do the trick:
#include
#include
int vprintf( char *format, va_list arg_ptr );
int vfprintf( FILE *stream, const char *format, va_list arg_ptr );
int vsprintf( char *buffer, char *format, va_list arg_ptr );
Example usage of vprintf:
void error( char *fmt, ... ) {
va_list args;
va_start( args, fmt );
fprintf( stderr, "Error: " );
vfprintf( stderr, fmt, args );
fprintf( stderr, "\n" );
va_end( args );
exit( 1 );
So, I could make my life really easy by going:
int LogPrintf( char *fmt, ... ) {
va_list args;
vfprintf( [pointer to log file here], fmt, args );
vfprintf( [pointer to CVI's debug output pane here], fmt, args );
va_end( args );
return 0;
How do I obtain a pointer to CVI's output pane to redirect my vfprintf output there?
(5,113 Views)
Even better, vsprintf formats the variable length argument list into a string that can then be easily passed to DebugPrintf and fprintf:
int EventLogPrintf (const char formatString[], ...)
static char buffer[EVENTLOG_MAXBUFFER];
int status;
va_list args;
va_start( args, formatString );
status = vsprintf( buffer, formatString, args );
DebugPrintf("%s", buffer);
fprintf([pointer to logfile stream],"%s", buffer);
va_end( args );
return status;
Thanks for your help getting me started on this!
(5,107 Views)
I think you have the right answer.  I was working from memory a bit and did not have a compiler in front of me to try it out.
Happy to hear you found a solution.
(5,103 Views)
