LabWindows/CVI
log. scale in graph control
Hello again
I have another problem with my application, hopefully someone can help me
again (thanks to Guillaume Dargaud).
I have an panel with a Graph Control. I want to display frequency data with
a log. x and y axis. But this does not work completly right. The control
often draws one unwanted line. This happend only when I use a log. x axis.
When I set the x axis to linear, the plotting is correkt.
I use PlotY with 1024 values (x axis) and value between 0.1 and 3.
Any suggestions ?
Stephan Gerhards
stephan.gerhards@ni.com
(3,868 Views)
Hello
I found the answer by myself: using PlotXY gives the correct result. PlotY
will always start the X value with 0, and this is not allowed with a log.
scaling
Stephan
Stephan Gerhards schrieb in im Newsbeitrag:
3961fc41@newsgroups.ni.com...
> Hello again
with
> Any s
uggestions ?
> Stephan Gerhards
(3,868 Views)
