LabWindows/CVI
loose the code completion
Hi...
I'm with the new versio of CVI... and when I go through file from the environment it has... some time... a hard time to refresh the window...
Plus now I lost the code completion feature... the radio button is on...
Is it'n kind of strange...
Best Regards...
Steph
(2,969 Views)
Steph,
You may want to repair the CVI installation, this is definatelly not something common. Just go to add/remove programs, find the NI software entrie and select change; then select CVI and run the change option, then just select repair the installation.
If the problem is consistent, please post more informaition so that we can help you out.
Juan Carlos
N.I.
(2,969 Views)
