LabWindows/CVI
<built-in> <command line> macro names must be identifiers
Ooops.  Here's the screenshot.
Message 11 of 19
(3,785 Views)
Hello S2rt and ichaus
Can you check whether you have some possibly incorrect Compiler Defines in Build Options(like in the image below)
Can you post a sample project that exhibits this behavior?
Constantin
Message 12 of 19
(3,762 Views)
Hello Constantin,
attached you will find my Build Options:
and
I can confirm that I do not change anything at that point when swapping between CVI2013 and CVI2012
Message 13 of 19
(3,753 Views)
Hello ichaus,
If you want to define the symbol O2 you need to put /DO2 in Compiler Defines. All the defines must be preceded by /D accordint to this help topic. I can confirm that I get the same error if I put /O2.
CVI2013 has a new compiler which doesn't accept the incorrect definition. 2012 seems to just ignore it, so probably you don't need it and you can remove it.
Constantin
Message 14 of 19
(3,740 Views)
Hello Constantin,
thats it. Good explanation and exactly faceing my problem. I removed the /O2 and restarted the development environment, then it works also with CVI2013.
Some years ago I tried the Intel Compiler for which this was a optimization flag, I suppose the old CVI just ignored it?
Thanks alot for the help.
Message 15 of 19
(3,735 Views)
Hello ichaus,
I'm glad the problem was solved. I've also created a bug, ID 438833 to give more conclusive error for this situation.
Yes, it seems CVI 2012 or older ignores it. If I write
#ifdef O2
 //some code
#endif
 the code is not executed.
In CVI 2013 you can set the optimization level from Options->Build Options, Configuration Options tab -> Optimization level for release configurations
Constantin
Message 16 of 19
(3,731 Views)
I too had a symbol defined in the compiler options.  It started with -D rather than /D.  Removing the define removed the error.
Thanks, Constantin.
Message 17 of 19
(3,700 Views)
Hi K_Joy.
I have the same error with all my *.c including excelreport.c (supplied by NI).
This file uses define's begining with underscore followed by a capital letter ( you said it is forbidden? ).
This file begins with:
/* L a b W i n d o w s / C V I */
/* Copyright (c) National Instruments 2000-2014. All Rights Reserved. */
/* Title: ExcelReport.h */
/* Purpose: Header file for CVI Excel Report Generation Instrument Driver */
/* Notes: This library communicates with the Microsoft Excel Automation */
/* Server via a generated ActiveX controller instrument driver */
/* (Excel2000.fp). This generated driver must be present to use */
/* this library. */
#include <cvidef.h>
#ifndef _EXCELREPORT_H_
#define _EXCELREPORT_H_
Message 18 of 19
(3,024 Views)
What happens when you remove the initial underscores?
Michael Keane
Message 19 of 19
(3,003 Views)
