LabWindows/CVI
making installer executables connect to devices
i have a program that has a bunch of different .fp's loaded in which the end-user can select which one their using to use my program.
My issue is that when I create an install, the end-user installs the program, but when running the program, it is not connecting.  I am trying to figure out why it is not working.  I thought I was doing it correctly by changing the target settings to include all their libraries and by adding their fp's to the Files.
i am just trying to figure out what I am missing?  Does the user need to install all the drivers manually like I have done when creating the program?
(3,780 Views)
function panels are available only while debugging a program, so that the programmer can use the provided functions conveniently. Accordingly, in an executable you can not connect or disconnect from a function panel (you can also not remove or change libraries that have been linked statically to your code).
(3,762 Views)
I understand the use of the function panels and debugging.  But for some reason, when installing my program, the program is not connecting to the instruments (scopes, supplies, etc).  I am wondering if I am not including certain drivers in the install or what the issue is.  The 488.2 driver was installed manually and works because I can connect manually using the MAX.
Also for instance, if I did not want to create an install, but just an executable, how would I do that?   If someone else runs my "release" .exe, I get .dll errors.
(3,752 Views)
OK,
sorry, so it's me who did not understand your sentence:
How can an end user run your executable and select different function panels?
(3,749 Views)
Sorry, They are not selecting function panels, but selecting which instrument they have connected.  So for instance, I have two different types of compatible scopes, and the user selects which one they have connected.
(3,747 Views)
Hi ngay528,
So if I am understanding you question correctly you are having errors when you deploy your application to another computer. I was wondering what errors you are receiving when you deploy the application? Also have you made sure to include in your installer all of the drivers you are using on your development computer. I saw that you are including the NI 488.2 driver but you also need to make sure to include the NI VISA driver (http://joule.ni.com/nidu/cds/view/p/id/1605/lang/en) Have a great day!
Best Regards,
Adam G
(3,732 Views)
