LabWindows/CVI
masked text entry for passwords?
I need to have a text entry box for passwords, like is common on the web, with the ***** showing when a key is pressed. How can I do this in LabWindows?
(3,293 Views)
We provide a custom control for this exact functionality. It converts a normal string control into a password style control. You can find the tool under cvi\toolslib\custctrl\pwctrl.fp. There is an example program that shows how it is used under cvi\samples\userint\custctrl\password\pwsample.prj
Best Regards,
Chris Matthews
(3,293 Views)
You will also want to consider the end-user "Pasting" text into the password box. The current implementation of the password control doesn't "Paste" well.
There is another forum question on this with responses.
Good Luck
(3,293 Views)
